UP GRADE FROM ROUTER TO SPINDLE
Discussion in 'CNC Mills/Routers' started by KEITHABEAR, Nov 1, 2019.
  1. KEITHABEAR
    I have a 1510 worker bee and wanting to up grade to a brush-less air cooled spindle, any recommendation would be appreciated
    I would strongly recommend staying with a router
    1) VFDs are complicated
    2) spindles are heavy and can flex extrusion based machines
    3) "lower noise" often considered a marketing point for VFDs, but most noise come from the stock/spoilboard and endmill during the cut
    4) VFDs spit out tonnes of EMI interference, often necessitating a total rewire to shielded cables, or battling grounding, ferrite, and other solutions to avoid controller interference
    5) spindles do not fit our router mounts
  3. Christian James
    Christian James Journeyman
    That's good advice!
  4. KEITHABEAR
    How long do the brushes last on the Makita compared to the Dewalt
  5. sharmstr
    According to shapeoko wiki, the Makita brushes last longer.
    #5 sharmstr, Nov 2, 2019
    Alex Chambers likes this.
  6. KEITHABEAR
  7. Alex Chambers
    Err..... that appears to say the Makita brushes last longer.
  8. sharmstr
    That's what I meant. Shoot. Sorry.
  9. IanBeaumont
    On the flip side and not to discourage you... (and not to take away from Peter's comments)
    1) VFDs have complex functionality but are easy to set up if you find a good set of instructions
    2) Perhaps try something like a 0.8kw spindle for a good balance between power and weight.
    3) My spindle is noisy when cutting, but slightly better than my router
    4) Use shielded wire when wiring up your machine - it'll probably save you all sort of headaches regardless
    5) "spindles do not fit our router mounts" - but there are plenty of spindle mounts available
    Perhaps we should ask what the motivation for wanting to "upgrade" to a spindle is?
