Understanding Feeds/Speeds and chip load
Discussion in 'Tutorials' started by Randy, Jan 11, 2021.
  1. Randy
    Randy Journeyman
    I am posting a link to a Youtube Video describing Chipload and how to get the most out of your bits.
    This is probably the best description I have ever seen so far for those of us that are new to CNC.
    I love the machines but there is no way your going to run at 100inch a minute on them so this fellow really helps to find the sweet spot.
    I hope this helps.
    Randy
    jda70az likes this.
    Last week I was doing about 70 inch a minute on my belt drive OX, 2mm 1flute bit at 18000 rpm in MDF.
    100"/min is not impossible, I do that when cutting insulation foam.
  3. Randy
    Randy Journeyman
    Wow. Well in any case I think this is useful information.
    #3 Randy, Jan 11, 2021
  4. Giarc
    I run at 2500mm/min (100 ipm) on wood and plastics all the time. With a ball nose I am doing about twice that fast.
    sharmstr and David the swarfer like this.
  5. Sidney Ropelatto
    Queridos colegas. Que aceleração eles usam para x, y, z?
  6. Sidney Ropelatto
    Please sorry. What steps to use on the drive?
  7. David the swarfer
    which drive, on what machine, belt or screw, what controller and what drivers?
  8. Sidney Ropelatto
    23hd56001y-21b, OX CNC, rnr eco motion, belt, tb6600.
  9. Giarc
    You need to know your microstepping, belt pitch, pulley size, etc... RepRap Calculator - Prusa Printers
    Mathematical formula here: gnea/grbl
  10. Sidney Ropelatto
    Thanks. But I was just wondering if anyone knows which step is configured in the drivers.
  11. David the swarfer
    My guess is that the documentation for the drivers will tell you how to set the DIP switches for microstepping.
    without the actual drive (google shows me about 3 different models of TB6600 driver) and the documentation it is possible to figure it out by experiment.
    if you set steps/mm to 1 then the motor moves 1 step for every mm you tell it to move.
    a 200 step per rev motor at 8x microstepping will do 1600 steps for a revolution, so telling it to move 1600mm you would see it do one revolution.
    if you tell it to move 1600mm but it only does half a rev, then microsteps must be 16x.
    Generally then, steps for 1 rev / 200 = microstep setting (assuming a 200 step per rev motor, these are common, but 400 and others do exist)
  12. jda70az
    jda70az Well-Known
    yeah that was useful thx
