Unable to "Save to Firmware"
Discussion in 'OpenBuilds Bug Report' started by Rick Wargo, May 22, 2024.
  1. Rick Wargo
    Hi,
    First, thanks for the great support you have shown everyone!
    I've been having problems getting my CNC to position from CONTROL. I've narrowed it down to an issue trying to save the firmware. It seems when I do that, I receive the error:
    When I press refresh, that field ($13) is always blank. The boolean drop down for this is different than the others. Note the circles instead of the check/x marks:
    I wonder if that has something to do with it.
    Running on a new Mac (M2 chip) with version 1.0.370.
    Thanks for the help.
    Rick
    Set $13=0 please - leaving it blank, the error is correct - it is NULL
  3. Rick Wargo
    Thanks for the reply, Peter. It is set to zero, but I set it again using $13=0 and the field remains blank. It always give me this error when I try to update the new settings.
    What version of CONTROL are you on?
  5. Rick Wargo
  7. Rick Wargo
    I swore I downloaded and installed 376 the other day... Unfortunately, the problem still persists. I am using a custom machine. I noticed, looking in the JS console, that $("#val-13-input").val() returns null, whereas $("#val-6-input").val() returns the string '1'. It appears that this control is different than the other booleans.
    I can set the value to enabled, save to firmware, restart grbl, but when it is refreshed, the field is blank again and I get the same error when trying to save.
    Please provide a Grbl Settings backup for review? Perhaps with your backup on a controller here I can replicate?
    Try setting $13=0 from the Serial Console?
  9. Rick Wargo
    It appears that $13 may have been skipped in grbl-settings. I added line 269 and the value appears after refresh.
    setTimeout(function() {
    $("#val-32-input").val(parseInt(grblParams['$32'])).trigger("change");
    $("#val-20-input").val(parseInt(grblParams['$20'])).trigger("change");
    $("#val-21-input").val(parseInt(grblParams['$21'])).trigger("change");
    $("#val-22-input").val(parseInt(grblParams['$22'])).trigger("change");
    $("#val-23-input").val(parseInt(grblParams['$23'])).trigger("change");
    $("#val-5-input").val(parseInt(grblParams['$5'])).trigger("change");
    $("#val-6-input").val(parseInt(grblParams['$6'])).trigger("change");
    $("#val-13-input").val(parseInt(grblParams['$13'])).trigger("change");
    $("#val-2-input").val(parseInt(grblParams['$2'])).trigger("change");
    $("#val-3-input").val(parseInt(grblParams['$3'])).trigger("change");
    $("#val-4-input").val(parseInt(grblParams['$4'])).trigger("change");
    }, 100);;
  10. Rick Wargo
    I guess I did not full test that, it appears that $13 stays at Enabled, even when setting it to disabled.
    $0=10 (step pulse,usec) ; Step pulse time, microseconds
    $1=25 (step idle delay,msec) ; Step idle delay, milliseconds
    $2=0 (stepport invert mask) ; Step pulse invert, mask
    $3=4 (dirport invert mask) ; Step direction invert, mask
    $4=0 (stepenable invert,bool) ; Invert step enable pin, boolean
    $5=1 (lims pin invert,bool) ; Invert limit pins, boolean/mask
    $6=1 (probe pin invert,bool) ; Invert probe pin, boolean
    $10=3 (status report mask) ; Status report options, mask
    $11=0.010 (junction deviation) ; Junction deviation, millimeters
    $12=0.002 (arc tolerance,mm) ; Arc tolerance, millimeters
    $13=0 (report inches,bool) ; Report in inches, boolean
    $20=0 (soft limits,bool) ; Soft limits enable, boolean
    $21=1 (hard limits,bool) ; Hard limits enable, boolean
    $22=1 (home cycle,bool) ; Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    $23=3 (homing dir invert mask) ; Homing direction invert, mask
    $24=100.000 (homing feed,mm/min) ; Homing locate feed rate, mm/min
    $25=500.000 (homing seek,mm/min) ; Homing search seek rate, mm/min
    $26=250 (homing debounce,msec) ; Homing switch debounce delay, milliseconds
    $27=1.000 (homing pull-off,mm) ; Homing switch pull-off distance, millimeters
    $30=10000 (maximum spindle speed,rpm) ; Maximum spindle speed, RPM
    $31=0 (minimum spindle speed,rpm) ; Minimum spindle speed, RPM
    $32=0 (laser mode enable,bool) ; Laser-mode enable, boolean
    $100=800.000 (X axis pulse:step/mm) ; X-axis steps per millimeter
    $101=800.000 (Y axis pulse:step/mm) ; Y-axis steps per millimeter
    $102=800.000 (Z axis pulse:step/mm) ; Z-axis steps per millimeter
    $110=2000.000 (X axis max rata:mm/min) ; X-axis maximum rate, mm/min
    $111=2000.000 (Y axis max rata:mm/min) ; Y-axis maximum rate, mm/min
    $112=2000.000 (Z axis max rata:mm/min) ; Z-axis maximum rate, mm/min
    $120=20.000 (X axis acceleration:mm/s^2) ; X-axis acceleration, mm/sec^2
    $121=20.000 (Y axis acceleration:mm/s^2) ; Y-axis acceleration, mm/sec^2
    $122=20.000 (Z axis acceleration:mm/s^2) ; Z-axis acceleration, mm/sec^2
    $130=400.000 (X aixs max travel:mm) ; X-axis maximum travel, millimeters
    $131=400.000 (Y aixs max travel:mm) ; Y-axis maximum travel, millimeters
    $132=80.000 (Z aixs max travel:mm) ; Z-axis maximum travel, millimeters
  11. Rick Wargo
    I changed the settings above for $13 as it is now stuck at 1
  12. Rick Wargo
    In the underlying settings $("#val-13-input").val() is now '1' (what I refer to as Enabled). Maybe because I patched the code in the JS console I am seeing this? Even though my change appeared to fix it, it was behaving oddly afterwards. Unfortunately, it did not solve my issue where the movement controls don't do anything. It appears that nothing happens on a click. I'll dig in more before posting a new thread. Thanks again for the help.
  13. Peter Van Der Walt
    that ones $4
    Should be$4=1
  14. Rick Wargo
    Unfortunately, it is set to 1. Thank you.
    [11:05:25] [ $$ ] $4=1 (stepenable invert,bool) ;Invert step enable pin, boolean
  15. Peter Van Der Walt
    Was $4=0 in Post #11 above
    Did you change it? Did you remember to reset (when prompted?)
    To move motors you only need $4=1 (for BlackBox 4X) and 24v power (does fan spin?)
  16. Rick Wargo
    Thanks. Good catch. I don't believe I changed it. It's odd that the screenshot captured 0 for $4. I'll be watchful. I can do all of the motion positions manually through the GCODE command line on CONTROL. I just don't think the click() event is hooked up to the buttons, but I am still investigating.
  17. Rick Wargo
    Back to the NaN issue... This is where I started, but I could not recall where I did see it. I realized it was trying to send a Feed command with NaN. So the click event IS enabled and working :), it just that the websocket is getting garbage.
    This is the content of the packet var in socket.js, line 268.
  18. Peter Van Der Walt
    clicking buttons has always worked. Any custom macros?
  19. Rick Wargo
    Nope. This is pretty much a plain vanilla setup. I'm still trying to figure out why a feed rate of NaN is emitted to the websocket. I believe that is the problem.
  20. Rick Wargo
    It appears I have a value in localstorage that is causing the jogRate override to occur. Unfortunately, the $110 is not a valid number and sets the jogRate to NaN. The easy fix is to remove localstorage.
    If jogOverride is called, then the grblParams must be parsed prior to using them.
    The UI now updates when pressing a button, but the head is not moving. I do have control over the spindle through the UI, though.
    I added the parseInt (like in grbl-settings.js) to the jogOverride function in jog.js. I believe this is a bug.
    function jogOverride(newVal) {
    if (grblParams.hasOwnProperty('$110')) {
    jogRateX = (parseInt(grblParams['$110']) * (newVal / 100)).toFixed(0);
    jogRateY = (parseInt(grblParams['$111']) * (newVal / 100)).toFixed(0);
    jogRateZ = (parseInt(grblParams['$112']) * (newVal / 100)).toFixed(0);
    $('#jro').data('slider').val(newVal)
    if (grblParams.hasOwnProperty('$113')) {
    jogRateA = (parseInt(grblParams['$113']) * (newVal / 100)).toFixed(0);
    localStorage.setItem('jogOverride', newVal);
  21. Peter Van Der Walt
  22. Peter Van Der Walt
    Not sure whats unique about your setup, but all this is working for the other couple thousand users. Before I'd consider something a real bug, i'd first weight up why it works for everyone else all these years.
  23. Rick Wargo
    I completely agree. It seems odd to me that this is happening, too; these are the last things I would expect. I love the software. It's really great.
    The value coming back from grblSettings[$key] is a string (most often, I have not seen otherwise), and it usually has the numeric value followed by a space and a short description. That won't work in the jogOverride function as it is set on my setup. Whenever I touch the jog slider, that routine get called and the jogRate values get set to NaN.
  24. Rick Wargo
    I am doing this investigation in the DevTools window. socket.js lives under build/esm/socket.js. That is where I first noticed this issue. But tracing it back on the stack I noticed it originated in the jogOverride routine.
  25. Rick Wargo
    That is an issue on my machine where the head is not moving. I think adding the parseInt would resolve this.
    [edit] grrrr. I had $4 set to 1 - that is why it wasn't moving. I set it back to 0, and with the parseInt() fix it is working (at least temporarily).
  26. Peter Van Der Walt
    Screenshot please?
    BlackBox 4X is definately $4=1. BlackBox X32 runs grblHAL (way more settings than the backup provided)
    Or. We aren't dealing with a BlackBox? Arduino with external drivers? Something that wasn't entitled to tech support anyway?
  27. Rick Wargo
    I am using a Genmitsu 4040 Pro and using OpenBuilds CONTROL to send the gcode. I was just trying to help out with the open source tool. BTW, the last comment should have been parseFloat, not parseInt. I submitted a PR with these two issues. Thanks again for the help.
  28. Peter Van Der Walt
    Please do state that earlier in any new threads. Would avoid us advising things like controller specific settings.
  29. David the swarfer
    puty a 0 in the blank field, then save
  30. Rick Wargo
    Thank you, Peter. I do not require help with configuration. I honestly believe the PR's I submitted are subtle bugs. I have run the GitHub code on my computer with those fixes and it works for me. I absolutely agree that it could be unique to my setup as this is very basic functionality, however, it is very clear to me as an engineer that those two fixes were not incorrect.
    I have been consistently able to reproduce this. I clean my application local settings within the Electron app, restart CONTROL, I get prompted to register, I connect to my CNC and I can position the head using the buttons. I can see the X/Y/Z coordinates change as expected as I use the buttons. I then move the jog dial to some other value (doesn't matter what it is). Then I try to press the X/Y/Z positioning buttons ($('xP') in the JS) and the CNC does not respond. When I repeat the same process with my changes, the final position step in the aboce scenario works.
    At this point I have a working solution (I am unable to use the positioning keys in CONTROL) to my issue. None of this was about configuration - just why CONTROL was not responding as expected. I tried to contribute to an Open Source project, that was all.
