Unable to connect to interface WiFi.
Discussion in 'General Electronics' started by Lorne Smith, Jun 7, 2023.
  1. Lorne Smith
    I have a new OpenBuilds Interface module connected to Blackbox 4X V2.10 on standard Lead 1010.
    All control functions are working as expected.
    Wi-Fi has never been connected.
    Wi-Fi icon is flashing green, not red.
    Can connect to INTERFACE 006800E on phone but nothing goes any further to finalize connection. See attached screenshot.
    Wi-Fi is 2.4G
    Unable to connect to 192.168.4.1.
    Reset interface. No change.
    Reset interface in Tools and Util. No change.
    I am missing something but I am unable to solve this issue.
    Can someone help me.
    Thanks.
    Lorne
    1) Make sure your Interface Firmware is up to date (V1. 57)
    2) Try a different phone
    3) Make sure Interface is fully booted up and on the Jog Screen.
  3. Lorne Smith
    My firmware was up to date.
    I tried 4 different phones.
    The first 3 were Samsung and did not work.
    The 4th was an old One+ and voila, it connected and I got it set up okay.
    Note that you must reboot the interface before it will be fully functional.
    Thanks for your help.
    Lorne
    Some Androids has a feature called "smart wifi" or something like that that switches data back to Mobile data when its on a Wifi that doesn't offer Internet access. The Interface is of course not a Internet connection, so that might be it, can be disabled in Settings
    Correct, as per Section 3 of docs:interface:wifi-setup [OpenBuilds Documentation]
  5. Justin Edmands
    Same issue here. It wont connect to wifi. It says that the wifi password is bad, but it's not.
    This may not work for everyone, but I changed my personal home wifi router 2.4GHz channel to "1" and it would connect.
  6. Carlbrady
    Carlbrady New
    I'm having the same problem,nothing else seems to be posted on this subject, so I enter here. I've tried to connect as per instructions, with no success. Firmware was updated via control (ver 1.57). I have a Samsung S8 and it shows the INTERFACE-000807,but connecting to it just says internet not available. The address to http://192.168.4.1 just times out. Maybe my router is blocking access, maybe the phone, but I would appreciate any advise to be able to resolve this. The icon for wifi is red INTERFACE-000807 192.168.4.1 and the status lit blinks green.
    Or your phone may be disconnecting from the Interface AP because its local only network. Check for a feature like Smart Wifi or something that Samsung may call it where it will "try to always find best internet connection" or try a different phone
  8. Lorne Smith
    Try disconnecting your S8 from your mobile network. In other words you are forcing your phone to only deal with wifi. I suspect that the phone does not like the temporary interface wifi link so it goes off looking for something else. I tried so many different things that I don't recall what actually worked. I know that it was something simple like the above. Sorry I can't do better. I have a very good memory but it is quite short most days.
  9. Carlbrady
    Carlbrady New
    I want to thank you for the responses. I finally got it to work, with another phone, an apple. And I was able to get a Samsung Ipad to pull up the screen. My SSID and passphrase are so long it would time out before I could finish, but with a little help I got it to save. Just a note for anyone else having a problem make sure to update firmware, or it will not save and you have to do it again.
