UGS, visualize returns to zero, machine does not???
Discussion in 'Control Software' started by James Marshall, Feb 1, 2023.
Tags:
  1. James Marshall
    Hi.
    Ive had an OX CNC for a few months now, it has been working fine but not the last 2 days. I am unable to zero the machine, I can set the zero at the correct height etc. But if I move the machine away from this by jogging it and click "return to zero" in UGS the visualiser shows the tool moving but it doesn't move. It freezes. It's like it loses its connection or something. Any help greatly appreciated.
    I have recorded a small video which hopefully I can upload.
  2. Christian James
    Christian James Journeyman
    What puzzles me in the video is that when you pressed "reset zero", the DRO did not go to zero as I would expect. Maybe an UGS problem rather than the machine?
  3. James Marshall
    Hmm, I have installed the latest version of UGS and the issue follows.
    If I try to run the file I just get the $$ settings and some g codes put back to me. Frustrating. Have scoured the web looking for similar issues but no luck.
    Sounds like serial queue bugs.. If its Grbl 1.1 try CONTROL from software.penbuilds.com
  5. James Marshall
    Very interesting, I will try this. Do you know why I might suddenly have these issues? You think it's with the UGS not the machine. I have not a clue what serial queue bugs are but this gives me hope.
    Many thanks. I will report back.
    Looks that way, thus trying different host to confirm or not
  7. James Marshall
    So I've downloaded openbuilds control, I have the same issue. The machine will not zero and will not run a job.
    I get this message when I click run job "gcode parser gcode file (from gcode editor) sent to backend.
    And that's it...
    What controller?
    Have you taken a backup (CONTROL > Grbl Settings tab > backup settings button) -And then post a backup of your Grbl Settings for review
  9. James Marshall
    I'm not able to get the backup settings right now, but still have the $$ settings on the screen if this is of use? Or else I will get out later and download them.
    Thanks again for the help.
    [16:31:36] [ $$ ] $0=10 ;Step pulse time, microseconds
    [16:31:36] [ $$ ] $1=255 ;Step idle delay, milliseconds
    [16:31:36] [ $$ ] $2=0 ;Step pulse invert, mask
    [16:31:36] [ $$ ] $3=6 ;Step direction invert, mask
    [16:31:36] [ $$ ] $4=1 ;Invert step enable pin, boolean
    [16:31:36] [ $$ ] $5=0 ;Invert limit pins, boolean/mask
    [16:31:36] [ $$ ] $6=0 ;Invert probe pin, boolean
    [16:31:36] [ $$ ] $10=1 ;Status report options, mask
    [16:31:36] [ $$ ] $11=0.020 ;Junction deviation, millimeters
    [16:31:36] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [16:31:36] [ $$ ] $13=0 ;Report in inches, boolean
    [16:31:36] [ $$ ] $20=0 ;Soft limits enable, boolean
    [16:31:36] [ $$ ] $21=0 ;Hard limits enable, boolean
    [16:31:36] [ $$ ] $22=0 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    [16:31:36] [ $$ ] $23=1 ;Homing direction invert, mask
    [16:31:36] [ $$ ] $24=25.000 ;Homing locate feed rate, mm/min
    [16:31:36] [ $$ ] $25=500.000 ;Homing search seek rate, mm/min
    [16:31:36] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
    [16:31:36] [ $$ ] $27=1.000 ;Homing switch pull-off distance, millimeters
    [16:31:36] [ $$ ] $30=1000 ;Maximum spindle speed, RPM
    [16:31:36] [ $$ ] $31=0 ;Minimum spindle speed, RPM
    [16:31:36] [ $$ ] $32=0 ;Laser-mode enable, boolean
    [16:31:36] [ $$ ] $100=26.667 ;X-axis steps per millimeter
    [16:31:36] [ $$ ] $101=26.667 ;Y-axis steps per millimeter
    [16:31:36] [ $$ ] $102=200.000 ;Z-axis steps per millimeter
    [16:31:36] [ $$ ] $110=10000.000 ;X-axis maximum rate, mm/min
    [16:31:36] [ $$ ] $111=10000.000 ;Y-axis maximum rate, mm/min
    [16:31:36] [ $$ ] $112=2500.000 ;Z-axis maximum rate, mm/min
    [16:31:36] [ $$ ] $120=50.000 ;X-axis acceleration, mm/sec^2
    [16:31:36] [ $$ ] $121=50.000 ;Y-axis acceleration, mm/sec^2
    [16:31:36] [ $$ ] $122=50.000 ;Z-axis acceleration, mm/sec^2
    [16:31:36] [ $$ ] $130=780.000 ;X-axis maximum travel, millimeters
    [16:31:36] [ $$ ] $131=1280.000 ;Y-axis maximum travel, millimeters
    [16:31:36] [ $$ ] $132=68.000 ;Z-axis maximum travel, millimeters
  10. James Marshall
    Also, it is an openbuilds xpro CNC V1.
  11. Peter Van Der Walt
    Sure its a V1? If so then 5. Troubleshooting states
    And you have
    So, if you are sure its a V1, that should be $4=0.
    ___
    Changed from the Grbl default of Grbl v1.1 Configuration which says it shold be $11=0.010 - adjusting advanced settings like those are never worth it, the defaults are tweaked already
    Rest looks OK
  12. James Marshall
    I stand corrected, it is a V2, apologies for the error.
  13. Peter Van Der Walt
    Well, V1, V2 and Matte versions of the V3 all fall under $4=0
    James Marshall likes this.
  14. James Marshall
    So I just changed $4 to 0 and $11 to 0.010, restarted GRBL and went to jog the machine. It juddered and now all is limp, like the steppers aren't holding now. I'm pretty confused:D
  15. James Marshall
    If I try to jog the machine this is what I get back:
    [21:29:28] [ $J=G91 G21 Y-1000 F10000 ] ok
    [21:29:28] [ $G ] [GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]
    [21:29:28] [ $G ] ok
  16. Peter Van Der Walt
    Power supply still good? xPro still good? It sounds like old / secondhand goods. V2 is a lot of years ago
    10000mm/min might be a bit fast:
    Try lower, like 3500 for XY
  17. James Marshall
    You are correct. It is second hand. I have changed the settings but no luck. I will try to re-flash the controller and if that doesn't work I think it needs a new one.
    Can you reccoment which one would be the best/ easiest direct replacement at all. Thanks. James.
  18. Peter Van Der Walt
    BlackBox - massive upgrade over an xPro: Learn more at docs:blackbox-x32:start [OpenBuilds Documentation]
    - 32 bit
    - Way stronger stepper drivers
    - Much easier to wire
    - 24V PSU (so if you ran the xPro off 12v, grab the 24v PSU too) for faster acceleration docs:powercase-v1.9:start [OpenBuilds Documentation]
    - Wifi
    - Full compatibility with CONTROL software and other more modern software toolchains docs:software:overview [OpenBuilds Documentation]
    - Optcoupled and filtered inputs to make it EMI proof
    - 4th axes support
    - Compatible with OpenBuilds Interface (So you don't even need a computer! docs:interface:start [OpenBuilds Documentation])
    - Compatible with our Probe: docs:xyzprobe:start [OpenBuilds Documentation]
    - Compatible with Xtensions Limits (A must have if you have plain switches now - Xtensions has onboard filtering and troubleshooting LEDs): docs:xtensions:limits [OpenBuilds Documentation]
  19. James Marshall
    Thank you, I think I'm convinced, I must say I far prefer the openbuilds software to the UGS, so if it ties in nicely then it should be a worthy upgrade.
  20. James Marshall
    Blackbox X32 ordered :D
    I just say, it's not the cheapest, but given my absolute lack of knowledge in Arduino, nor willingness to invest time to learn it I think it's the best choice.
    Can't wait to get it installed and get going again using the openbuilds controller. It's much more user friendly than UGS from what I've seen.
  21. Peter Van Der Walt
  22. James Marshall
    Just got the new blackbox installed... Wow! I had read that the machine sounded smooth as butter but in my head failed to see how it could with the same parts... I see now! Such an improvement!
    Loving it :D
  23. James Marshall
    Quick one, and thanks for all the help so far.
    When I open my gcode file, the viewer shows it as being out of the machine limits (see image). I'm not sure if this matters as I haven't come to cut anything yet. But I would like to be able to set the origin of my file to the origin of the machine, is this possible?
  24. Peter Van Der Walt
    1) home to set Machine Coordinates
    2) Jog to the origin (center of stock it seems from the screenshot) and Set Zero
    Machine Coordinates and Work Coordinates are seperate "layers"
    G53 = Machine Coordinates
    G54-G59.1 = multiple Work Coordinate systems, all stored as Offsets from Machine Coordinates
    G28/G30 = defined positions as offsets from Machine Coordinates
    Rehoming automatically re-establishes all saved Coordinate/Coordinate Systems too
