Two limit switches in same Blackbox port
Discussion in 'CNC Mills/Routers' started by Mark Stephens, Mar 26, 2020.
  1. Mark Stephens
    Hello everyone! I'm just about finished up with my build and have a question. If I want to add a second limit switch to the x and y axis, can I simply plug both both x limit switches into the x limit switch port on the Blackbox and both y limit switches into the same y limit switch port on the Blackbox?
    Thanks a lot,
    Mark Stephens
  2. Alex Chambers
    What sort of switches have you got? Normally open (including the Extension limit switches from Openbuilds) need to be wired in parallel, so yes to your question. Normally closed switches need to be wired in series.
  3. Mark Stephens
    Thanks Alex! They are the limit switches from Openbuilds. Sounds easy enough to plug them both in. Thanks a lot!
