Touch off error with Blackbox
Discussion in 'OpenBuilds Bug Report' started by Sylvain Michaud, Jun 5, 2021.
  1. Sylvain Michaud
    Hello everyone,
    I have beviator from openbuilds control updated ver. .300 and after on my cnc with Blackbox Lastest version.
    The touch off sequence work good for many week and nothings change on my setup.
    I use sheetcam for creating .nc
    When I load gcodes G32.1 are not make and Just past to next command.
    Can you help me ?
    The error indicates your probe is already switched when you try to probe. Ie faulty switch, wiring or $6 parameter
  3. Sylvain Michaud
    I check another time for this possibility.
    Alarm apear when touch off probe switch are triggered.
    Same gcode.. run two, three ore more time not the same result
    thank for your help
