Touch interface Issues
Discussion in 'Control Software' started by William Campbell, Jan 24, 2021.
  1. William Campbell
    issue I, I can seam to up date firmware using the wifi, it connects, it says downloading 1.43 firmware, then I get in red can't install not enough space.
    issue 2, i have the open build prob plus, but when I pro with interface xyz, i get a no numerical data error
    does any one know what I'm doing wrong?
  3. William Campbell
  4. William Campbell
    I thinks is working serial control on computer sat starting touch screen is black and all green lights
    Click Reset on the side to reboot if it doesnt reboot itself
    Oh and make sure you have CONTROL v1.0.275
  6. William Campbell
    is it suppose to say start still,
  7. William Campbell
    it seams to be hung up on (firmware upgrade). starting.......
  8. romamaker
    romamaker Well-Known
    Make sure you follow those directions to update from Control Specifically, make sure you hold down that "mode" button when you hit the reset button on the Interface. And continue holding until the flash starts.
    hold Mode on Interface... click Flash in control... immediately hit Reset on Interface, continue holding Mode until flashing starts.
  9. William Campbell
    I did, I did. to all Mac owners that have this problem. pay attention to the top of the direction sheet where it says " windows only for now " OMG this was killing me, No Macs. Im good now!!!!!!!!
    #9 William Campbell, Jan 24, 2021
