Tool paths and GCode not generating
Discussion in 'CAM' started by Joe Rutowski, Dec 6, 2023.
Tags:
  1. Joe Rutowski
    Hello I am trying to use SVG files to create tool paths for my 1515 with blackbox. I am uploading the SVG then assigning values, depth of cut, etc to each tool path and once it is done generating GCode, but it does not seem to be working. It won't simulate tool paths and doesn't seem to be working in controller. I did it all day yesterday and it worked perfectly. The issue seemed to start this morning. I attached one of the files that I was working on this morning.
    Post the WORKSPACE export for review please. File > Export Workspace OBC.
  3. Joe Rutowski
    Here you go!
    You left CUT DEPTH START "empty" - set it to 0
  5. Joe Rutowski
    Thank you for your help. I knew it had to be something simple!
