Terminal size on switches?
Discussion in 'General Electronics' started by jeffmorris, Jan 11, 2021.
  1. jeffmorris
    jeffmorris Journeyman
    Those are not suitable for home/limit switches.
    What are you going do with the switches?
  3. JustinTime
    JustinTime Veteran
    If you are looking on how to connect to them than most likely the easiest way is to solder to the connectors. There are special crimp plugs for them but they are a pain to crimp and to work with and need special crimping tool.
  4. jeffmorris
