Tech support for Javascript Macros in CONTROL
Discussion in 'Control Software' started by sharmstr, Jan 4, 2021.
  1. Peter Van Der Walt
    Misterg likes this.
  2. Misterg
    Misterg Veteran
    Correct
    Misterg likes this.
  4. Niuulh
    Niuulh New
    Error 9 directly with v2, but this time for G38.3 no issues with G21 and G4
    G38.3 is probe with no error. Try G38.2 so you can see what the Probing error was?
    The .3 is hiding the true error that causes the lockout in the first place. Error 9 always comes after some earlier error/alarm, and they key is knowing what that one was... With G38.3 you don't know why the probe failed, you only see the next symptom of it being locked out
    G38.2: Probe towards the stock, error on a failure.
    G38.3: As G38.2, no error on failure
  6. Misterg
    Misterg Veteran
    I see it ran through a couple of probe cycles OK.
    The original error was on G21 still, but this got repeated for the G38 command. The first two G38.3 commands competed OK.
    I have no idea.
    Is anyone else with a BB32 willing to try out this macro to see if they get the same error?
    I see. Jog command ran. Content of string did trigger the $G checker (not needed, but shouldnt hurt)
    But then it was already locked when the G21 was sent. Whatever Errored or Alarmed did so silently before the G21 was even sent
    Error 9 is the symptom, of an earlier error/alarm that placed Grbl into a locked out state (ALARM state usually) - why we don't see that one being raised is interesting and the silentness made me wonder about the G38.3
    [13:35:22] [ $J=G91G21Z2F1000 ] ok
    [13:35:22] [ $G ] [GC:G38.3 G54 G17 G21 G91 G94 G49 G98 G50 M5 M9 T0 F200 S0.]
    [13:35:22] [ $G ] ok
    [13:35:22] [ ] error: 9 - G-code locked out during alarm or jog state [ G21 ]
    [13:35:22] [ ERROR ] error: 9 - G-code locked out during alarm or jog state [ G21 ]
  8. Niuulh
    Niuulh New
    Here's new log with G38.2
    Misterg likes this.
  9. Misterg
    Misterg Veteran
    As previously, the probe completed OK (the G9 error started at the G21 command again). I *might* have sussed it though:
    The macro is commanding a Z move with a feed of 1000.
    Your machine is set for a maximum Z speed of 1000 mm/min.
    Can you increase your Z maximum speed setting ($112) to something >1000 (1100, say?) and then try re-running the macro?
    Niuulh likes this.
  10. Niuulh
    Niuulh New
    Same with increased speed :(
  11. Misterg
    Misterg Veteran
    I give up ! :banghead:
  12. Peter Van Der Walt
    MisterG you have regular Grbl right? Not grblHAL?
    One last thing we can try is just latest grblHAL (our included image is from around May 2023)
    http://svn.io-engineering.com:8080/?driver=ESP32&board=BlackBox X32
    Just incase its a grblhal bug of some sorts. With latest firmware if it persist we can perhaps ask Terjeio (grblhal dev)
  13. Misterg
    Misterg Veteran
    I’m using GRBL_ESP32 (just to complicate matters!)
  14. Peter Van Der Walt
    That really does! Hehe
    But that means you could try grblHAL as you have an ESP based board?
  15. Misterg
    Misterg Veteran
    Yes, when I've got a minute I'll flash a spare ESP32 with GRBL_HAL and see what happens. It's not a standard board, though, so I need to cross-check the I/O assignments.
    (ETA: I can probably try standard GRBL more quickly.)
  16. Misterg
    Misterg Veteran
    OK, that was quicker than I thought it would be (I basically only needed to worry about the probe pin):
    With standard GRBL (V1.1h) on a fake Arduino Uno the macro runs OK.
    With GRBL_HAL (freshly flashed from Control) I get 'error 9' as reported by @Niuulh
    (As an aside, I noticed that the probe status in the troubleshooting tab doesn't seem to work in GRBL_HAL, but it does for standard GRBL despite this, the 'Z' probe routine (for example) successfully detects that the probe contact has closed.)
  17. Peter Van Der Walt
    Misterg likes this.
  18. Misterg
    Misterg Veteran
    $10 was already set to 511 (I loaded a machine configuration from the library in Control) - I set it to something else, set it back & restarted everything and the probe flag still doesn't seem to work on the diagnostic screen.
    I downloaded the new firmware and flashed it, and now the probe dooesn't work at all :rolleyes: - I will investigate further tomorrow after I've had a good sleep!
  19. Misterg
    Misterg Veteran
    OK, I have done some more testing, but am not very much wiser....
    The probe diagnostic thing went away (possibly my shonky wiring on the test ESP32).
    I have tried the following without success (still error 9):
    i) The current version of GRBL_HAL;
    ii) The current version of GBBL_HAL compiled with the compatability level set at 10;
    iii) Reverted back to the version of GRBL_HAL that Control flashes
    iv) Altered macro to avoid possible trailing or leading newline characters*
    v) Altered macro to build strings to send using explicit \n character rather than relying on newline in the editor* (notepad++)
    vi) Altered macro to replace $J command with G0*
    vii) Altered macro to remove commands in the job string after the G38.2 probe command
    viii) Reverted back to an earlier version of the macro
    All of the various versions of the macro ran OK on standard GRBL on an Arduino Uno clone, and on GRBL_ESP32 (which Control detects as standard GRBL, I think).
    I then set up a port sniffer to compare the communications between standard GRBL and GRBL_HAL (current verson flashed from Control).
    I can detect *no* difference in the strings sent in each case, yet this causes an error 9 in GRBL HAL.
    For reference, the commands that are sent are:
    Code:
    G21
    G53 G0 Z-5
    G30 G91 X0 Y0
    G30 G91 Z0
    G21
    G38.3 Z-45 F150
    G4 P0.4
    $J=G91G21Z2F1000
    G21            <--------------I think this causes error 9 under GRBL_HAL
    G38.3 Z-5 F30
    G4 P0.4
    $J=G91G21Z2F1000
    G21
    G90
    As far as I can tell, the code above is perfectly legit, but for some reason, GRBL_HAL flags up an error.
    I've attached several files from the port sniffer (I have deleted some of the idle messages and replaced them by [...]):
    The zip file contains two html files that show all communication in sequence with TX and RX colour coded (these are the easiest to make sense of).
    The XXXwrite.txt files show the hex characters sent by the computer.
    The XXXread.txt files show the hex characters sent by the ESP32. (The activity in both of these are time stamped, so it is possible to read them side by side.)
    I am completely at a loss at the moment!
    *The original syntax is the one used for several of the sample macros, and as per the sniffer files, generates the expected code :
    Code:
                    var tc_probe =  `
                        G21                    ;set mm mode
                        G38.3 Z-` + tc_seekdistance + ` F` + tc_seekspeed + ` ;probe using parameters at the top of the macro
                        G4 P0.4                ;pause
                        $J=G91G21Z` + tc_retract + `F1000    ;jog up by retract paramter at the top of the macro
                    socket.off('prbResult'); // Disable old listeners
                    socket.emit('runJob', {
                        data: tc_probe,
                        isJob: false,
                        completedMsg: "",
                        fileName: ""
    [Edit - added the serial log from when GRBL_HAL connects for version numbers, etc. Control is v1.0.370]
    #139 Misterg, Sep 11, 2023
    Niuulh likes this.
  20. Peter Van Der Walt
    Great testing. Lets tag in @terjeio :)
    Niuulh and Misterg like this.
  21. Peter Van Der Walt
    Theres a lot of spaces after the G21, before the semicolon for the comment. Might be worth a shot, but i would have expected it to be filtered. I don't think we filter spaces, as I am quite sure Grbl ignores them and we avoid modifying the job as much as possible. Sorry out of office, just caught my eye on a second look through.
  22. Misterg
    Misterg Veteran
    No worries - I get the same response if the string is built like this:
    var tc_probe = "G21\nG38.3 Z-" + tc_seekdistance + " F" + tc_seekspeed + "\nG4 P0.4\n$J=G91G21Z" + tc_retract + "F1000\n";
    From the port snooper, neither the spaces or the comment are sent, anyway.
  23. Peter Van Der Walt
    Figured. Sorry shot in the dark... And a Miss. It happens
    Misterg likes this.
  24. Misterg
    Misterg Veteran
    I hate unfinished business:
    @Niuulh - try this, if you wouldn't mind?
    It works on my GRBL_HAL test setup (just a bare ESP32 and a probe switch!) and on my GRBL_ESP32 real machine.
    Thanks.
    [Edit 17/9/23 - FIle deleted to avoid duplication. Please see this post instead. ]
    #144 Misterg, Sep 15, 2023
    Peter Van Der Walt and Niuulh like this.
  25. Niuulh
    Niuulh New
    I set ref tool then 10 times new tool and it run flawless !
    i'm gonna try it with actual jobs and let you know after some used time
    Thank you so much !
    Misterg and Peter Van Der Walt like this.
  26. Peter Van Der Walt
    Curious, what was it?
  27. Misterg
    Misterg Veteran
    Yay!
    The $J command was the problem. It seems that GRBL_HAL will not accept any other commands after a $J within the macro, even though standard GRBL does. I thought I had eliminated this in earlier testing, but apparently not.
    I'll update the version in the other thread assuming no adverse report from @Niuulh
    Niuulh and Peter Van Der Walt like this.
  28. terjeio
    terjeio Well-Known
    Due to faster processor? The code where the error is raised is pretty similar, grblHAL vs Grbl.
  29. Niuulh
    Niuulh New
    Used it all day and no issues so far, works perfect for me :)
    Misterg likes this.
  30. Misterg
    Misterg Veteran
    I suspect that throwing the error should be the expected behaviour, but for reasons I have been unable to fathom, the same macro generates an error in GRBL_HAL but not in GRBL. In further testing, I have been unable to recreate this outside the macro execution (e.g. just sending GCode strings).
    (I don't know why the $J command was originally used to retract the tool after probing - I just copied one of the examples :oops:)
