Stop after fisrt operation
Discussion in 'OpenBuilds Forum Help' started by Martí Aracil, Dec 17, 2023.
  1. Martí Aracil
    Hi, I'm using OpenBuilds with Arduino GRBL to run a DIY plasma cutter. The first operation run perfectly: cutting, movement, everything was okay. But after turn off the plasma cutter (M05), the software goes crazy. It moves to random coordinates (only in the software, not the machine) and then stops.
    I tested with the plasma off and it does the same thing. With simulation mode, the program runs perfectly.
    Any idea?
    I'll attach a link to a YouTube video of my problem.
    Thank you very much, and sorry for my bad English
    Possibly a HF plasma? They aren't suitable for CNC - too much EMI. Get a Blowback/LF start plasma.
    The arduino has no filtering or shielding either, replace it with a proper controller like a https://docs.openbuilds.com/blackbox-x32
  3. Martí Aracil
    Hello, thank you, but this isn't the problem. With the plasma disconeted ,do the same...
    Genuine Arduino, or chinese fake with CH340 USB chip?
  5. David the swarfer
    please upload the gcode
  6. Martí Aracil
    it's chinese fake with CH340 ... Could this be the problem?
    I attach g.code
    • PC2.nc
      File size:
      1.8 KB
    They are notorious CH340 and speed setting · Issue #294 · gnea/grbl
    Drops characters when their internal buffer is near saturated.... Causes lots of flow errors, serial corruption.
  8. David the swarfer
    gcode is ok, probably the USB chip.... possibly the USB cable, use a good, shorter one.
  9. Martí Aracil
    I have changed the cable and the Arduino board and now it works. I don't know exactly where the problem was, but it seems like it would be the board.
