STL File
Discussion in 'CNC Mills/Routers' started by Docktergreg, Jun 22, 2024.
  1. Docktergreg
    How do I load a STL file for carving on OB 1515? I have Blackbox x32, OB Control, OB CAM. Also Fusion360, and Inkscape. I attached the file I want to carve. I tried to load it into CAM, but it won't load. Do I need to convert to another format, and if I do, what converter would I use?
  3. David the swarfer
    import it into fusion360, convert from mesh to solid, apply paths in manufacturing, post gcode (using the openbuilds post! link in my signature below)
    Alex Chambers likes this.
