Stepper Motors
Discussion in 'Motors' started by Michaei, Jan 14, 2023.
  1. Michaei
    Michaei New
    Stepper motors are moving in the opposite direction when jogging. Please help.
  2. Giarc
    Which ever motor is going the wrong direction, take one pair of the motor wires and switch them around.
  3. Giarc
    I assume that was for a Y axis where it was causing the gantry to rack. If not, you can easily change directions in the grbl settings. You can invert the $3 setting for each axis.
  4. Michaei
    Michaei New
    Giarc, Thank you very much. Everything seems to be working at it should.
  5. Michaei
    Michaei New
    Why do the motors have a humming sound?
    Because thats the normal sound a stepper makes while braked because steppers use pseudo sine waves created by a chopper driver
  7. Michaei
    Michaei New
    Thanks, Peter, for the information. Maybe you can help me with the xyz probe. I can't seem to get it to work on the black box 32X. Any help to resolve this issue is greatly appreciated. I have tried everything except reversing the wires. Not sure if it would damage the black box.
  8. sharmstr
  9. Michaei
    Michaei New
    Sharmstr, Sorry the probe doesn't move or respond.
  10. Michaei
    Michaei New
    Sharmstr, Thank you for the help. Probe is working.
