stepper acceleration question
Discussion in 'CNC Mills/Routers' started by Lybrary, Sep 5, 2022.
  1. Lybrary
    Lybrary New
    In the profile files for the various machines provided I see acceleration numbers ranging from about 100 - 350 mm/s^2. I am a bit surprised at how high these are. I am using the BlackBox with Nema23 high torque steppers and I can't get to 50 mm/s^2 without stalling. I am running them at 30 mm/s^2. Just wondering what the difference could be. I do use ballscrews which require 400 steps/mm whereas the leadscrews of the various OB machines require 200 steps/mm. I think this explains part of the difference because in my case the steppers have to turn twice as fast to get to the same mm/s speed, but that is just a factor 2.
    Heavy ballscrews are harder to spin up than our 8mm leadscrews. The lower pitch further adds to that
  3. Lybrary
    Lybrary New
    That makes sense. Thanks for the explanation. Is there a way to change the microstepping to 1/4 or 1/2? In the docu I only see how to increase it to 1/16 and 1/32.
  4. Gary Caruso
    Did you try increasing your current as well?
    Gary
  5. Lybrary
    Lybrary New
    Yes, I did. It did not make a big difference.
