Start up/ end code question
Discussion in 'Laser Cutters' started by Gizmo6, Aug 5, 2023.
  1. Gizmo6
    Gizmo6 New
    How would you program a delay between pressing start and the machine moving?
    I am using a relay to control my exhaust fan and laser power supply and neither powers up instantly once the relay contacts close. I need a 15-20 second delay for the fan to spool up much less for the laser power supply to come on line. Would also be nice to have the fan run for a while after cut completion to evacuate the fumes before opening the enclosure door.
    BlackBox X32 with an IOT relay and Lightburn for control.
    Add a G4 P20 to Dwell in place for 20 seconds
  3. David the swarfer
    but it really should be an option in lightburn rather than manually editing code every time
  4. Gizmo6
    Gizmo6 New
    Thank you, I will look in Lightburn and see if that is an option and will make a note of the G4 P20 just incase.
  5. Gizmo6
    Gizmo6 New
    There is an option in the cut settings editor Advanced tab for Start and End pause time the article I found says you must enable Cut Through to enable the pause. Will give it a try in the morning when the shop isn't 100 degrees.
  6. Gizmo6
    Gizmo6 New
    The Lightburn Start/End pause works as advertised BUT, it disables using the laser while framing which I find to be a very handy feature. Will give G4 P20 a try next and hope that doesn't break another feature I use.
