Stability difference between c beam plate and double wide?
Discussion in 'CNC Mills/Routers' started by James Scott, Dec 5, 2019.
  1. James Scott
    Hey,
    I'm wondering how bad the stability difference was between the C beam plate and the double wide? I just received my order and when looking through everything I realized my mistake. I plan on using a 1.5kw spindle and will only be cutting wood/plastic/foam.
  2. Giarc
    I would think you should be fine. That is a pretty commonly used size. Also, if one of the Chinese 65 mm mounts came with it, those are a significant chunk of metal which will also add stiffness to the plate.
  3. James Scott
    Yes it has the aluminum holder with it. Just didn't know the torsional strength difference between the 2 but thanks I'll try the normal c beam plate first.
