Spindle causing issues
Discussion in 'CNC Mills/Routers' started by Chadfarmer, Dec 18, 2019.
  1. Chadfarmer
    Got a 800w spindle and got the cable that is shielded ( lol because it would cause no interference) I got it a minimum 4 inches from all other wiring on my machine. And here's the problem my machine just pauses for no dam reason just out of the blue. I put router back on and it runs program fine. Spindle does the pause through the computer. I noticed that my x limit switch is active 100% of the time now too
  2. Giarc
    Did you ground the shielding on the cable? Are your signal wires (limit switches) shielded and grounded?
  3. Chadfarmer
    How do you ground the shielding?
  4. Chadfarmer
    I grounded the shielding by the top of the the plug. The y limit switch is always on no matter what I do. Do u have pics so I can compare to mine.
  5. Giarc
    I do not have pictures. However if you Google information regarding shielded wiring there is a lot of tutorials and explanations on how and why you ground the shielding.
  6. Chadfarmer
    I did that correctly I moved to wires about 6 inches away and has ran 1 hour no stop. We will see how it goes. But thanks for the help. We will see
