Software went crazy HELP!
Discussion in 'General Talk' started by Carlos Urquidi, May 10, 2022.
Thread Status:
Not open for further replies.
  1. Carlos Urquidi
    Ok, so I was doing my business went to my kitchen for coffee, my job was finished and I told the mobile widget to go to zero (spindle off, of course) and It went crazy, first started going downwards on the x axis, tried to abort, finally it did but now my machine has a clanking sound on the X axis
    Help, I suppose I have to dismantle stuff but don't know where to begin.
    Link to video: https://youtube.com/shorts/yw-B8QCzpCA
    #1 Carlos Urquidi, May 10, 2022
    Duplicate of support ticket logged on support.openbuilds.com - check your email for replies
    Just an additional tip:
    The up/down axis is the Z axis. X is left to right. Y is back to Front. Assuming from your video you mean Z, not X
    Secondly, GOTOZERO goes to Z+5 first (normally bit is still on the stock or in the cut, so the 5mm lift up is a safety feature - however if you were above Z5 already, it would appear to go down first (but stop 5mm above the stock zero) and then move X and Y
    Alternatively, use the GotoZero in Machine Zero option (Lifts Z up to homing switch, then moves XY)
Thread Status:
