software help
Discussion in 'Control Software' started by Phil Harris, Dec 6, 2023.
Tags:
  1. Phil Harris
    Hello I have built a backstop for my brake press but I'm having problems creating G code program that I can then save for future jobs how do I even start the program off all I have is one axis Y that goes in and out. All I want to do is make programs it for different stops for different parts
    i was thinking
    Y100
    Y20
    Y-20
    etc
    so its moves 100mm then 20mm then back 20mm
    do i need to get certain software to write this for the open builds controller?
    you can create Gcode macros for OpenBuildsCONTROL
    you can move in absulute mode (the default)
    G21 G90 G0 Y100
    moves to the position 100mm from the WCS zero position (1)
    similarly
    G21 G90 G0 Y200
    moves to 200mm from the zero position
    You can move incrementally
    G21 G91 G0 Y10
    moves 10mm in the positive direction (like the jog buttons do, do you actually need more than the jogs buttons?)
    G21 G91 G0 Y-10
    moves 10mm back (toward 0)
    note that I am putting the modal commands G21 and G90 or G91 in every macro, this is the safest way to do it as you don't know what the previous command was unless you check it everytime. I cannot remember to do that but I can remember to always put the command I want into the macro and knwo that it will always work. This is how all macro programs should start, setting the modes you need, metric/inch,abs/inc,plane (G17) and so on.
    (1) the WCS zero is wherever YOU set it. search these forums for 'fake the home' for info on howto and making this easy and repeatable.
    Phil Harris likes this.
  4. Phil Harris
    Thank you very much for the reply I will give it a go.
