Snap Maker 10W laser head
Discussion in 'Laser Cutters' started by Matthew Stevens, Apr 15, 2022.
  1. Matthew Stevens
    So I was online and saw an ad for the new snap maker 10W laser head. they say it can cut 8mm in one pass in basswood. Has anyone begun to investigate this? Apparently you can purchase just the head and software for under 500$.
    I remember spending about 700$ for a 7W laser head. Any thoughts??
    Thinking about a retrofit to my CNC Lead machine
    #1 Matthew Stevens, Apr 15, 2022
    Technological limit of diode lasers are 5-6w. Anything else is Marketing (sometimes lies)
    I doubt it would do 8mm in one pass, definitely not plywood (maybe balsa). Plywood is almost impossible to cut on a diode laser - 445nm works on organics, which resin based glue is not. Cuts OK through the wood layers, expect 3-4 passes per glue layer
  3. Matthew Stevens
    I hear you. looks like the internal mirrors help with it. Don't know all the science involved but it looks worthy of investigation considering the sticker price.
    I meant BASSwood and not plywood, original post edited
    Snapmaker 10W High Power Laser Module - Snapmaker
  4. Giarc
    Yeah. Those are two 5 watt lasers combined with mirrors. I looked at some of those at one point and I realized I could get a separate 40 watt CO2 laser cheaper. But, those tubes do need to be replaced every so often at $120-140 a pop. So, I have yet to decide if that decision was right.
    Gary Caruso likes this.
