Smoothieboard now in Part Store
Discussion in 'Announcements' started by MaryD, Feb 17, 2017.
  1. MaryD
    MaryD OpenBuilds Team
    What are the voltage input range and stepper output limits (Amps) on this board?
  3. Kyo
    Kyo Master
    Nice :thumbsup:
    With the large delta build under way I have been on the fence between Duet wifi or a Smoothieboard. Being able to grab it right from the OB parts store along with other misc. pieces I need made that a easy decision. Excellent timing.
    @Rick 2.0
    The Smoothieboard allows a voltage input range of 12-24V according to the wiki. V1.1 uses the Allergo A5984 drivers I believe they have a peak output of up to 2A.
    PhotoSgt85 and MaryD like this.
  4. PhotoSgt85
    PhotoSgt85 Veteran
    Just be mindful that if you are running external drivers that you are going to have to configure it to open drain as the board can only source 3.3V to external drivers.
  5. Glenn Weston
    Glenn Weston Master
    Sorry but I am a little confused.
    Is this the "BAD BOY" that the naming competition was centred around ?
    It seems to fit the specs that was initially announced, if it is, I am off to purchase one and who was the competition winner ?
    I didnt see any announcement....
    Cheers Glenn
  6. MaryD
    This is not the same controller as the contest. News on that coming soon.
  7. Glenn Weston
    Glenn Weston Master
    OK cool.... I will hold off then.
    Thanks Glenn
