SketchUcam No Parameter
Discussion in 'CAM' started by curnowdj, Mar 10, 2020.
Tags:
  1. curnowdj
    curnowdj New
    Hello,
    I am running Sketchup 2015 on wine with Ubuntu 18.04. I installed SketUcam 1.4 extension without issue but when I click on the Parameter icon the panel opens but it is empty. There is nothing at all in the panel.
    you need to use compatible dialogs
    SketchUcam: HOWTO set default options
    OR
    you need to install IE extensions for WINE, part of the winetricks package IIRC.
    this is because the normal parameter dialog is actually a web page that is rendered by Sketchup using the IE engine.
  3. curnowdj
    curnowdj New
    Thanks. I installed IE8 and parameters are all good.
