Simple 20X20 Belt-and-pinion System
Discussion in 'OpenBuilds Forum Help' started by greymather, Apr 12, 2022.
  1. greymather
    Hi there. I'm brand new to v-slot systems, so sorry if this question is a bit basic.
    In the V-Slot Belt & Pinion System video at 0:45, a simple gantry is shown mounted on a 20X20 v-slot rail:
    But I can't see any build information given for this setup.
    I feel like I'm missing something simple, but I see in the video that the setup works fine. Is there a reason there are only examples of 20X20 with an idler pulley loop setup instead of belt and pinion? The only one I can think of is that the cord has to move with the motor, where-as the belt-driven one is more stationary.
    I think the parts I would need are:
    But there's no way to confirm.
    For a bit of context, the project this is for is just a simple device that moves a small tube that distributes liquid. The tolerance could be up to a cm, and I'll probably cannibalize it after I'm finished.
    Any help is greatly appreciated!
    The actuator kits are just some of the more popular assemblies kitted together - use the complete parts catalog (like lego for adults) - to put the modular system together in just about any way you can imagine
    If in doubt, plan it out in CAD: OpenBuilds | 3D Warehouse
