Shift in Code
Discussion in 'CNC Projects' started by Chris Wailes, Dec 5, 2020.
  1. Chris Wailes
    Hello everyone. Has anyone had a problem with code slightly shifting on the x-axis while carving? I am using Fusion 360 to generate the G-Code and OpenBuilds Control to send it.
    1) check mechanicals (loose setscrews on pulleys / shaft couplers, etc)
    2) check wiring (loose terminals in motor wiring , intermittently loosens and lose connection)
    3) check current adjustment
