Sherline CNC lathe conversion
Discussion in 'CNC Lathes' started by Tourniquet63, Mar 7, 2024.
  1. Tourniquet63
    I have gotten ahold of a sherline CNC lathe. It is complete with steppers but does not have any controller board / drivers.
    Can I use the blackbox to retrofit this?
    Possibly, depends on the electrical specs of the motors. Try look for a datasheet of yours
  3. Tourniquet63
    It is a small lathe. The two steppers are listed at 2.1 amps. The sindle motor is listed at 90V DC but I have the DC electronics speed control board. I will have to figure out how the Blackbox can control this board. It looks as though it is normally controlled manually through a potentiometer. So maybe a digipotentiometer (Digital Potentiometer - 10K - COM-10613 - SparkFun Electronics) could be used and controlled by the blackbox?
    #3 Tourniquet63, Mar 8, 2024
    Are they Bipolar? Voltage? (3-6V for BlackBox ideally, higher will limit acceleration), Inductance? (1-2mH ideally, higher will be slower on top speed) - that's why the datasheet's important - you need the full picture, all values, not just one parameter
    We provide industry standard 0-10v and PWM outputs. Does this board have a manual or other documentation to see what inputs its accepts?
  5. Tourniquet63
    Yes the steppers are 3.2V. I believe the inductance is 3.6 but I will have to get a mutimeter to measure it for sure.
    I contacted Sherline for any documentation available on the board. The most common use of the board though is to just be controlled with a physical potentiometer.
    Should be usable then.
    Spindle we'll confirm when we get more details then.
    In the meantime, checkout docs.openbuilds.com > Software and also the BlackBox X32 sections
  7. Tourniquet63
    Thanks Peter. An immense help as always!
  8. Tourniquet63
    Still working on this build.
    I wanted to make sure these limit switches would work. They are the stock switches on the sherline cnc lathe. Closest part I could find.
    Looking at the documentation they are most like the lever micro limit switches - I just wanted to make to make sure that they should read as open when connected, and then closed when pressed.
  9. Peter Van Der Walt
    Or other way round. Just match up $5 Invert settings.
    Without filters Normally Closed might be a little better
    Tourniquet63 likes this.
