SheetCam and OpenBuilds Control Question
Discussion in 'Control Software' started by Dov Rosenberg, Jul 10, 2024.
  1. Dov Rosenberg
    I have been using Fusion 360 with my JD Garage based plasma cutter. I generate the g-code using an openbuilds post processor that works fine. If I move to Sheetcam, is there a post processor available/needed in order to use the generated gcode compatible with OpenBuilds Control?
