Sharkbits Specs
Discussion in 'CNC Mills/Routers' started by Pok3, Jun 7, 2021.
Tags:
  1. Pok3
    Pok3 New
    The following bits are not in the tool database that can be downloaded and imported into Fusion 360.
    Upcut 2 Flutes Solid Carbide Ball Nose End Mill 1/4" Nano Shield
    Upcut 2 Flute Solid Carbide End Mill 1/16" Nano Shield
    3 Flute Surfacing Bit
    Upcut 2 Flutes Solid Carbide End Mill 1/4" Diamond Carbon
    I've tried downloading VCarve Pro Trail to see if I can import its tool database but it seemed the trial version does not support this. Are these bits in the VCarve tool database and if so can someone please send me a screenshot of the setup parameters?
    Some of the newest additions haven't been added yet, but use the nearest similar flute count and diameter as a starting point. Tool databases are always just a conservative starting point, for optimum performance you should really maintain your own, specific to your machine
    Christian James likes this.
