Setting jogging defaults
Discussion in 'Control Software' started by GS76, May 2, 2021.
  1. GS76
    GS76 Well-Known
    Hi there,
    I have a small CNC milling machine, maximum travel of 15 mm for each axes.
    I am using v1.0.300 of OpenBuilds control software on Windows.
    I wanted to ask if it is possible to setting the jogging to "incremental jogging" with an increment size of "0.1 mm"? Please see attached image.
    And where would I set the jogging feed rate speed?
    Thank you and as always thank you for the great product.
    Switch to Continuous Jogging and use the Slider to dial down for more control.
    Your machine is way smaller than the majority of machines around here, so we cannot otherwise accomodate it, sorry.
    Here: gnea/grbl - the Jog Speed slider is 1-100% of this value
  3. GS76
    GS76 Well-Known
    Hi Peter,
    Thank you for all the information.
    This helps a great deal.
