Sensor PHC with blackbox
Discussion in 'Laser Cutters' started by Kevl4r, Mar 1, 2021.
  1. Kevl4r
    Kevl4r New
    Hi,
    I have found an second hand Hypertherm Sensor Plasma Height Controller for my Powermax 45xp
    Is it possible to use the Blackbox controller in conjunction with the Hypertherm Sensor PHC ?
    Has anyone done this before ?
    Thanks for any insight.
    Grbl does not support torch height controllers.
    We recommend a floating head design
  3. Kevl4r
    Kevl4r New
    Thanks Peter.
    To fire ON/OFF the torch I will need to connect the pin 3 and 4 of the powermax CPC to a dry contact relay.
    Can the Blackbox relay be used as a dry contact relay ?
    Yes. See plasma section of docs.openbuilds.com/blackbox
  5. Kevl4r
    Kevl4r New
    I was looking at this very piece of documentation, but I was unsure if the actual relay was dry or not.
  6. Kevl4r
    Kevl4r New
    here is my build with the floating head.
    I am waiting for the Plasma torch to arrive from the USofA
