Selection of Laser head for cutting and engraving
Discussion in 'Laser Cutters' started by KTLighting, Oct 22, 2019.
  1. KTLighting
    Hello everyone!
    I am really new to this. I have a Workbee 1500x1000 with a router configuration. I am planning to expand it in dimensions. Can anyone suggest me a kit that can transform it to a laser cutter/engraver? I want to cut 3-5mm acrylic.
    Thank you in advance
    My machine is this:
    OpenBuilds Workbee 1500x1000mm Natural
  2. Giarc
    Giarc Master
    You will most likely need a CO2 laser for that. That will greatly complicate things. Read through some of the CO2 laser builds here to get some ideas. Many have bought the cheap K40 laser and used a few Openbuilds parts to easily increase the cutting area.
  3. KTLighting
  4. Alex Chambers
    I'm afraid you will not cut 3-5mm acrylic with those - you need much more power (40 - 50 Watts).
    #4 Alex Chambers, Oct 23, 2019
  5. Giarc
    Giarc Master
    Well, according to Opt Lasers, it can cut 3 mm plexiglass an 2 mm per second. But they only appear to claim that for red and green. https://optlasers.com/manual/laser-head-test-1-plh3d-6w-optlasers.com.pdf
    But, for the price I could buy 3 k40 40 watt CO2 lasers that I know would cut what you want and way faster. Plus it is a designated machine so you do not have to worry about dust from your spindle messing with the optics of the laser, unless your plan was to remove the laser head everytime you used the spindle . I bought a K40 so I could get the components to modify it with Openbuilds parts and make a much better laser system with a rotary axis incorporated like what was recently posted in the laser section of this forum.
  6. KTLighting
    Thank you! I will look into it.
