sanding/smoothing tools?
Discussion in 'CNC Mills/Routers' started by halfshavedyaks, Jan 9, 2019.
  1. halfshavedyaks
    halfshavedyaks Well-Known
    I am cutting mostly smooth curves in 3D in wood with little fine detail. Accuracy is important but the surfaces are smooth not detailed.
    I've been finishing with a 1/2" ball at 7% overlap. Tt still leaves ridges that have to be sanded out by hand and take longer to do so than I would like, especially as the finished part is quite fragile and I can't apply much force.
    I would like to try some sort of sanding attachment with a effective area of approx 5-10mm. A little bit of averaging of the surface within that radius would be acceptable.
    does something like that exist?
    I'm wondering about something like this, but smaller:
    New Dome Sanding Mop/ Polishing Mop Polishing 180Grit Dia.48mm | eBay
  2. halfshavedyaks
    to clarify - I want something to use in the CNC machine - not in a handheld tool afterwards.
