I want to just route around the perimeter of a DXF image. I am using Fusion 360 and when I try to do a 2D contour around the image the bit does not carve into the wood. I realize that I need to tell Fusion how deep to go but haven't found where I would put that setting. Thanks, Joel
Set the stock to leave to a negative number. Its in the passes tab. Edit: Axial stock is what you set, not radial.
