Router moving the wrong way
Discussion in 'CAM' started by bo Toepfer, Aug 19, 2020.
  1. bo Toepfer
    I have designed and cam'd a few parts, the last one as the others, this time I as before used the XYZ probe, made sure the Tri arrows pointed in the right direction, and wehn checked the probe all sett to zero, hit run job and the router moved 180 degrees from were the simulation said it would go? lost again
  2. Rob Taylor
    If you type in G91 G21 G1 X80 Y80 F300 and hit go what direction does your spindle move?
  3. bo Toepfer
    I will give this a try Today when I got back to the machine I did everything the same and it cut the parts as I designed twice.
