Richauto A11 help !!!
Discussion in 'OpenBuilds Forum Help' started by Julie Markham, Sep 22, 2024.
  1. Julie Markham
    Hi all, can someone please help me, I have done something ridiculous,
    I have zeroed all 3 axis WHEN in the home position, what do I do to get my coordinates back
    to what they should be when in the home position, thank you in advance for all help,
    regards, Mike
    not sure I understand what you are seeing.....
    home is machine 0,0,0 (Machine Coordinate System), set by homing
    when you 'setZero' you are setting Work Coordinate System offsets, which are relative to home.
    If you now jog to where your material zero is and setZero (or jog close and probe), the display will show zeros, and if you then hover your mouse of each axis display the popup will show the machine coordinate values.
    Further, if you issue a $# command in the serial console it will display all the offsets for all the WCS systems, G54 through G59
