Requesting help for a newbie
Discussion in 'General Talk' started by Jonathon Clark, Nov 3, 2022.
  1. Jonathon Clark
    Good morning all and thanks for taking the time if you do. I have just finished building a LEAD 1515 and have done a couple of small things but and trying something and keep getting and errow. I have no gotten to the designing of things so I decided to buy a file from Etsy. The file came with both the DFX and the G Code files but when I import the G Code file into OpenBuild Control I keep getting the error in the picture. I am not sure what it means or how to fix it. Any ideas out there?
    Thanks again for the help.
    You need Grbl compatible GCODE. Your GCODE contains commands that Grbl does not support. You'll have to CAM it in a Grbl compatible CAM. See the software section of docs.openbuilds.com
