Rattm 2.2KW Square Air Cooled Spindle Motor
Discussion in 'CNC Mills/Routers' started by Rob Atha, Jul 6, 2019.
  1. Rob Atha
    Rob Atha New
    Hi All
    Ive been looking at upgrading the spindle I have on my workbee 1050.
    I currently have a 24v er11 Chinese spindle Machifit ER11 Chuck 500W Spindle Motor with 52mm Clamps and Power Supply Spe | eBay but im after upgrading as i find it a little under powered.
    I've been looking at a Rattm 2.2kw 2400rpm air cooled spindle s-l1600.jpg 『UK&EU』 2.2KW Square Air Cooled Spindle Motor ER20 24000rpm 6A 4000HZ CNC Router | eBay but as i'm just starting out in cnc, i'm not sure whether this spindle requires a VFD as im looking for something that really I can just connect to my Xpro V4 for spindle speed control.
    I am restricted on space in my shop which is why I use air cooled spindles and don't really want to have to find room to house the VFD, so if anyone can help or make recommendations i would really appreciate it
  2. Gary Caruso
    Hi Rob, Yes this spindle requires a VFD, and is probably too heavy for a Workbee
    Simplest solution would be a small router like the Makita RT0701 or the Dewalt 611, will be loads more power than what you have now.
    For on/off control an external relay would be used. easy way is with this.
    Gary
  3. Rob Atha
    Rob Atha New
    Thanks Gary.
    I do like the idea of the switched relay but I’m in the uk, using 230volt type G plug. Is there a way of adapting this switch or will I need to make my own? (Any links on how to do this world be helpful)
  4. Alex Chambers
    We couldn't possibly give you advice on making your own for obvious legal reasons - fortunately there are 230V versions available - try Amazon or Google - I had a link to one a few weeks ago, but can't find it at the moment - will post it here when I do.
  5. Alex Chambers
    #5 Alex Chambers, Jul 7, 2019
  6. Rob Taylor
    Note the inrush current paragraph at the bottom of the page, since we're dealing with inductive devices here.
    Team Yorkshire!
  7. Rob Atha
    Rob Atha New
    I’m in leeds. And thanks for the help Alex. It’s a pity that sparkfun have only brought out an American version, it would have been ideal for connecting directly to the cnc and dust extractor
    #7 Rob Atha, Jul 7, 2019
  8. Gary Caruso
    Could always use a 40A SSR like I always do and wire yourself, if comfortable with that.
    In rush, on a router With variable speed is not much as they typically soft start.
    Gary
  9. Alex Chambers
    Yes - the one I have found so far is a bit expensive - will keep looking, might want one myself. I thought about building a combined on/off and speed controller but can't share the details of that idea because of liability concerns.
