Ratrig stronghold set up with openbuilds
Discussion in 'CNC Mills/Routers' started by Kyung, Sep 14, 2024 at 8:21 AM.
Tags:
  1. Kyung
    Kyung New
    Saturday
    Hi!
    I’m currently setting up my Ratrig Stronghold one 1250x1250.
    I downloaded openbuilds control and I don’t know if I can use of the openbuilds setting. Is there any existing model that is compatible with my Stronghold one or should I go for the custom option?
    load the LEAD 1515 profile and then adjust as needed after you have motion.
    you will need to calibrate
    Kyung likes this.
