Random grbl errors 1 and 2
Discussion in 'OpenBuilds Bug Report' started by Whitedog, Aug 29, 2022.
  1. Whitedog
    Whitedog New
    I am using Openbuild Control with Win10. I get unrepeatable GRBL errors. Job stops at different place every
    time and never finishes. Using a 3' USB cable. changed cables and USB ports on computer. I don't have this problem with other gcode senders. Can I turn off error reporting? Hope you can help.
    Whitedog likes this.
  3. Whitedog
    Whitedog New
    I am using GRBL ESP32. I have several machines using this processor. Your EMI document was helpful. Ordering some chokes and double checking grounds. Thanks for the help
    Note that CONTROL only supports standard Grbl Home · gnea/grbl Wiki
  5. Whitedog
    Whitedog New
    GRBL_esp32 6 pack is the board I am using. It is running GRBL 1.3
    CONTROL only supports the official Grbl firmware from GitHub - gnea/grbl: An open source, embedded, high performance g-code-parser and CNC milling controller written in optimized C that will run on a straight Arduino
    You may want to approach your board vendor for their recommendation on software for their boards
    Or checkout the BlackBox at docs:blackbox:start [OpenBuilds Documentation] for a fully supported solution that works perfectly with CONTROL. Also has better EMI immunity, filtered inputs, etc
