Quick question on belt driven actuator - newbie
Discussion in 'General Talk' started by JP Scott, Nov 21, 2019.
  1. JP Scott
    JP Scott New
    hi huys and gals,
    I could really use your advice. I'd like to build an actuator probably using a c-beam sitting on its side where the stepper motor is fixed vertical and moves a plate with printer head back and forth along the length of the beam.
    The only video i could find is a belt drive that moves the plate and motor. So, this idea is a bit different.
    Cheers from Colorado,
    Jim
  3. JP Scott
    JP Scott New
    Thanks David
