question on stepper motor temperature
Discussion in 'Laser Cutters' started by uverseman, Aug 2, 2023.
  1. uverseman
    uverseman New
    Building laser, using many spare parts from an Ender 3d printer. Using the Nema 17's 42-34 by Creality for X and two Y's. They are are running very hot, almost burning to the touch, even when setting idle as I am still calibrating. Using the X32 box as controller. I have the current turned all the way down as per the instructions in the controller docs.
    I verified and rechecked all pin wiring from the motors to the board and all is correct. Tested coils with ammeter to be sure that are A+A-, B+B- as indicated on the board.
    Are these motors up to the task? or am I overlooking something?
    The minimum output current is around 1.2A (perfect for our NEMA17s). If yours are overheating they may be too small for use with BlackBox
  3. uverseman
    uverseman New
    yes I sort of figure that... I just checked my motor and it's rated for 0.8 a, so yes, this is the issue. Thanks, I should of looked at this before I wrote here, too simple.
