Question about collets for Bosch 1hp Colt.
Discussion in 'General Talk' started by jda70az, Jan 17, 2021.
  1. jda70az
    jda70az Well-Known
    Hi
    Anyone here using a Bosch Colt 1hp pr20evs ?
    The question I have is what other collets will work with this router?
    It comes standard with a 1/4th inch collet and I'm looking for a 1/8th inch collet.
    I need that to be able to use end mills with an 1/8th inch shaft.
    What are you guys using?
    jda70az likes this.
  3. jda70az
    jda70az Well-Known
    #3 jda70az, Jan 17, 2021
    It's not a collet. Its an adapter. Fits in your (or absolutely ANY) 1/4" collet, then fit the 1/8" endmill inside the adapter
    See video below, from 2min8seconds onward
    jda70az likes this.
  5. jda70az
    jda70az Well-Known
    Thanks for the help.
  6. Rick 2.0
    jda70az likes this.
  7. jda70az
    jda70az Well-Known
  8. Giarc
    They are nice. I have both the metric and the imperial sets for my Makita. Now it would be cheaper to just buy the Router11 and an additional 4 and 7 mm ER11 collet for the same functionality. If only the Router11 was around 6 years ago.
    jda70az likes this.
  9. jda70az
    jda70az Well-Known
    What Makita are you running?
  10. Rick 2.0
    Except for the part about having to buy a whole system in order to get one...
  11. Giarc
    Oh. I did not see that.
  12. Giarc
    The Makita RT0701C. I picked that one several years ago due to its lower rpm range.
    jda70az likes this.
