Proper way to trigger a solenoid at high frequencies
Discussion in 'Controller Boards' started by Marcsallent, Aug 6, 2021.
Tags:
  1. Marcsallent
    Hi!
    I'm using the Blackbox controller and I want to trigger a solenoid at a quite high frequency, 4-8 times per second (as much as possible actually).
    I am exploring the following g-codes:
    Code:
        # Use Flooding on/of and connect it to the solenoid
        M8
        G4 P0.02
        M9
        # or use the 0-10v Analog Output
        M3 S1000
        G4 P0.02
        M3 S0
        # ... continue
    Can any of them be electrically or electronically specially taxing to the controller?
    Thanks!
    You shouldn't use the analog 0-10v to run solenoids directly, that would cause damage to the BlackBox. The 0-10v analog signal is just a signal (couple milliamps, meant to be fed into a VFD or similar spindle controller) - it's also not really suited to your case even with additional control circuitry - as its a linear scale, not an on/off.
    The coolant output should handle it fine, it's what it was designed for: docs:blackbox:connect-coolant [OpenBuilds Documentation] - use a 24v solenoid, try keeping it under 1000mA (Most standard solenoids are around 200-300mA)
    Marcsallent likes this.
  3. Marcsallent
    Thanks Pete
    I saw the info about the coolant valve / solenoid but I was worried that the frequency of my intended use (4-8Hz) might be an issue for the controller
    thanks!
  4. David the swarfer
    Not an issue for the controller, but will certainly kill the solenoid in a relatively short time, they do have a limited life span.
