Problem with workbee build
Discussion in 'CNC Mills/Routers' started by gorrilladiver, Jun 8, 2019.
  1. gorrilladiver
    just got the motors and black box wired up on the workbee that i'm building. Conected to my windows 10 laptop and the openbuilds and it seems to connect to the blackbox. using the preconfigured setup for a workbee 1050. When i click on the jog buttons nothing happens except for a small twitch from the motor on that axis. On the y axis only one of the motors will twitch. I have the motors wired up red to a+ blue to a- green to b+ yellow to b-. where should I start to troubleshoot this, would it be a problem with the control software, the black box, or the motor wiring?
    Staff Member Moderator Project Maker Builder Resident Builder
    Just make sure you did load it using OpenBuilds CONTROL (not CAM) and did Save.
    $4=1 (Enabled)?
    RV6APilot likes this.
  3. RV6APilot
    RV6APilot Well-Known
    Interesting is that my BlackBox does not have any preconfigured setup for the WorkBee. Should it have?
  4. sharmstr
    sharmstr Master
    OB Control has a profile for the Workbee. Load it and make sure you set $4 to 1. Save to Firmware, then go through the calibration wizard (in the Wizard and tools menu) for each axis.
  5. RV6APilot
    Thanks @sharmstr I will check that out here in a few minutes. I have been using the Lead1010 to this point. I will look for the Workbee
    config. From your image I assume it is under the GRBL settings.
  6. sharmstr
    sharmstr Master
    Yep. Thought that was clear by the image so I didnt mention it. Sorry.
  7. RV6APilot
    I thought that is where it was, just wanted to confirm.
  8. gorrilladiver
    $4=1 (Enabled)
    this was set to disabled in the default setup. changed to enabled and it works now!
    thank you!
