Problem with software
Discussion in 'General Talk' started by Anang Dwi Purnomo, Jul 4, 2020.
  1. Anang Dwi Purnomo
    I have problems with the software, I can't use run job function to run my g code file, so what should I do?
    Staff Member Moderator Project Maker Builder Resident Builder
    1) check machine is properly set up
    2) check that its not locked/alarmed
    3) check the serial log for clues
    4) make sure the gcode is grbl compatible
    Post screenshots and gcode file for more help
  3. Matthew Stevens
    I have a question, Been running for a while now on my HP Omen desktop computer. Hooked it up a MAC I just acquired, got that running, now my HP wont recognize my black box controller and I'm dead in the water. Any suggestions?
  4. Matthew Stevens
    It still works with the MAC, but I only use it really to move around the axis
  5. Roger Beseke
    Did the USB driver get removed or perhaps corrupted?
    Try different ports on the Hp.maybe a dead usb port. Different cable, device manager, reboot, reformat. The usual windows trickery
  7. David the swarfer
    Wondows huh? always put it back in the USB port it was plugged into. Using a new USB socket changes the COM port number....
  8. Matthew Stevens
    I've attached a screenshot. I did get the port to talk once but it didn't connect as you can see from the screenshot. Somewhere I read to try to flash the box. that didn't work. Should have never plugged it into a MAC. Tried all the ports. The ports all individually work with an external media device. Still works on the MAC no problem.
    Side problem:
    The MAC will stop in the middle of a job, but if you press pause then go, it will continue as normal.
  9. Peter Van Der Walt
    Screenshot again, but dont crop it. Show the whole window, might have clues. Also screenshot device manager with Ports expanded
  10. Matthew Stevens
    sorry, the window got closed. I'll try again
  11. Matthew Stevens
    oh, I see what you mean. FYI, I tried it 3 times, the string above the crop is the same
  12. Matthew Stevens
  13. Matthew Stevens
    asked for a manufacturer and model, not sure which one to pick. I downloaded the driver files separately, and also the installer version. Still says no driver installed.
  14. Peter Van Der Walt
    Wanted to see the whole window, top toolbar, whats in the port selection, etc. Not the log :)
    BlackBox as FT232 on it, refer docs:blackbox:install-drivers [OpenBuilds Documentation]
    But your computer's chipset drivers also seem messed up, so head over to the motherboard manufacturer's support pages, grab latest chipset/usb drivers and reinstall those too
  15. Matthew Stevens
    Problem Solved. Cable too long. (9ft) I bought an extra cable recently. Worked fine until I started noticing intermittent communication issues with mac while running programs. Wouldn't connect at all with the PC. Note to self. Don't use an extra long cable for USB without power booster.
    Boathpy and Peter Van Der Walt like this.
  16. Matthew Stevens
    Thanks for all the help!!
  17. Peter Van Der Walt
    Yes, never use long USB cables! Its a nightmare. 5 feet max :)
  18. Giarc
    Giarc Master
    I feel so guilty - or lucky - when I see you repeatedly tell people this. My USB cable is 10 feet long and I have never had a problem. :) But I have also not tried any long 3D relief cuts. For everyone else, don't listen to me.
  19. Peter Van Der Walt
    Purely luck. Or a good PC. Most cheaper motherboards have USB chips with weak signals, or susceptible to EMI
    Giarc likes this.
  20. Boathpy
    Boathpy New
    I would have made this exact same mistake.
