Problem with moving X-axis during work
Discussion in 'Laser Cutters' started by MatheusPL, May 26, 2024.
  1. MatheusPL
    MatheusPL New
    Hello,
    Recently, the X axis has been moving while engraving. It looks like in the photo. Is this the fault of the program (LightBurn)? I've already checked it on the tablet, OpenBuilds Controller, installed updates and checked the mechanical connections on the X axis. What could be causing this problem? I also add my GCode. Anyone have some Ideas? I have the same problem with milling.. Maybe its the motor fault? 20240526_183830.jpg
    Perhaps Max Rate set a little high in Grbl Settings?
  3. MatheusPL
    MatheusPL New
    It was the motor fault. I changed the motors on the x and z axis and the problem appeared on the z axis. I bought a new one and the problem disappeared
