Problem loading DXF into CAM
Discussion in 'CAM' started by ClaudeJER, Dec 30, 2018.
  1. ClaudeJER
    ClaudeJER Well-Known
    What is the trick to load a DXF file into CAM software. I have tried from a few different sources, Fusion360, Inkscape, Solidworks and nothing works, What am I doing wrong? Or should I ask what should I do to make sure the DXF file parameters are right ?
  2. Gary Caruso
    Can be tricky making sure everything is on one plane and not 3D.. I use draftsight and it's basicly Autocad 2D and works great for making DXF for Estlcam.
    Gary
    DXF R14, Polyline format. Not all DXFs are created equal.
    To ensure polylines in Solidworks: Go to File – Save As select .dxf then select options and make sure “Export all splines as polylines” is selected.
    Also make sure its been 'flattened' - ie not 3D geometry
    Here's a couple sample DXFs to play with (Attached)
    Gary Caruso and Mark Carew like this.
