Probe Issue
Discussion in 'General Electronics' started by Randy, Aug 16, 2020.
  1. Randy
    Randy Journeyman
    Hi folks,
    I am having an issue with the probe traveling too far on the y-axis and plunging down on the wire connector jack. It has not broken anything but I can not use it at this point.
    I am not sure how to change the travel amount or if it is possible. I have seen nothing in the Documents regarding this. I centered the bit in the hole just above it as in the video.
    I am using a 1/8th bit.
    I could do it manually I guess but that takes the fun out of using the technology.
    Thank you in Advance
    Randy
    Is your steps per mm set accurately? Use the Calibration Wizards under Wizards and tools
  3. Randy
    Randy Journeyman
    I will check it. Actually I was going to ask about that also. I started doing that the other day but unlike my 3d printing machines I do not see a button that will set the esteps to where they need to be once I do a 100mm measurement. They are off a little for sure.
    Sorry I am not explaining this properly. I will have to wait a while to run it again, It's still pretty early here and wife gets grumpy if she is woken up to soon. lol
    Randy
  4. Randy
    Randy Journeyman
    Ok I figured it out. Not sure what the heck I was doing before. The steps were not off by much but I will put the prob back on and test it again.
  5. Randy
    Randy Journeyman
    Ok I think everything is where it should be. Steps are set and the Probe Test worked without issue this time. Sorry to have taken up your time.
    Randy
    Always happy to help!
  7. Randy
    Randy Journeyman
    I case anyone else has a issue. Home your machine first. Check your Steps and correct if needed and then Set up your Probe. Worked like a charm. funny how one mm can bugger things up.
    Thank you Sir.
    Homing doesnt come into play with Probing but spot on on the rest.
    If the steps per mm is off then none of the planned moves will be spot on. I tend to tell people to run a couple jobs using manual zeroing before trying probing. Its better to understand the process before it gets too easy.
