PRGM INCH AND IT IS EXICUTED IN METRIC
Discussion in 'OpenBuilds Bug Report' started by METLSHPR, May 22, 2021.
  1. METLSHPR
    METLSHPR New
    When i run g code that should make a 5 inch square carving i get one about 1/4 inch square. it is like the execution of the code is done in metric. when i manually jog machine it is moving the amount correctly. is there a setting somewhere?
  2. Christian James
    Christian James Journeyman
    It's doing what the g-code is telling it, so yes, it looks like the file has been created in mm.
  3. Giarc
    Choose the "Openbuilds grbl inches" post processor. Or the "grbl inches" post processor. The gcode should be right then.
  5. Alex Chambers
    It shouldn't make a difference with the Vectric post processors based on the grbl ones - they correctly convert units and put the right g-code (G20/G21) in the header. So if you design in inches and use a grbl (mm) post processor the g-code would be in mm and come out the right size.
  6. METLSHPR
    METLSHPR New
    All I need to do was put the G20 at the top of the code.
    Thanks all!!!
    Giarc likes this.
  7. Alex Chambers
    The correct post processor should do that for you.
  8. David the swarfer
    Rather use the correct post processor so it is always correct and you don't have to remember to fix it for every project
