Power supply switch for power supply
Discussion in 'General Electronics' started by GS76, Jan 4, 2024.
  1. GS76
    GS76 Well-Known
    To whom it may concern:
    I have two Meanwell power supplies, one for the spindle and one for the Openbuilds X32 Blackbox controller.
    I operate with 220VAC in South Africa.
    Power supply for controller is a Meanwell LRS-350-24 supply for 24 volts to the controller.
    Power supply for the spindle motor controller is a Meanwell LRS-350-12 supply for 12 volts to the motor controller.
    I would appreciate a recommended switch for each one. I want each power supply to have a switch.
    Thank you.
  3. GS76
    GS76 Well-Known
  4. GS76
    GS76 Well-Known
    I have only checked the kit I recieved now and I do not see the M3x10 spacers.
    I want to replace them. Am I correct they were made of plastic.
    I am based in South Africa and I am looking for a supplier. Any suggestions would be appreciated.
    Regards.
    Best to contact the store if anything was missing
    But Communica, Mantech, RS, Hobbytronics, maybe even Robotics.org.za should all stock M3x10mm female-female spacers.
    HP-10 - SPACER PLASTIC FEM-FEM M3x10
    Takelot has little variety kits of all sizes too
  6. GS76
    GS76 Well-Known
    Thank you, Peter,
    Much appreciated. I was mainly concerned it they were made of plastic/nylon.
    Thanks again.
    Does not matter :) nylon is cheapest. Brass is nicer. Whatever you can find, they just mount the front panel mechanically. Boer maak plan can work too
  8. GS76
    GS76 Well-Known
    Great Thank you!
